Minolta bizhub C203.
  • edd the red
    I have minolta bizhub C203.It has error code c4153,i think it is print head, can it be fixed without replacing head.
  • Spidula
    Konica Minolta Technician
    • 83
    Re: Minolta bizhub C203.
    Yellow laser unit. You will have to swap it out if the code wont clear with opening and closing the door, turning off and on etc.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        You are supposed to replace the entire set of 4 matching print heads when one malfunctions.
        However, i have in emergency situations installed a second hand single print head, even of the wrong model and it worked without issue for the few days till i got back there with the new kit. By wrong model i mean install 20/25 ppm heads in a c353, and the polygon motors are not rated for the extra RPM's required but did not self destruct in the short time span it was in place.
