Try a Different screen (LINE 1 or Line 2)
also try different screen frequencies for the line you are using. Lower frequency equals smoother colour
Kind regards.
Trying to change the screening is the fastest way to solve it. If not, try in Service Mode to run Auto Gamma Adjustment and Printer Gamma Offset Adjustment.
I would think that is the first thing to replace on any color issue.
I would think if the conrona's are due or even close i would change them, they are cheap parts. I never let the corona's go longer then 50K - i get them from KATUN they work well and are just as good as OEM.
