BH C452 J72-26 Booklet Folding
  • bafaction
    • Aug 2010
    • 2
    I have a C452 that is getting a J72-26 jam, The customer is doing a booklet job and this error is very intermittment, When this jam happens the booklet is folded and stapled but about 3-4 pages on the inside of the book have not moved down with the rest of the pages so when it is stapled the these pages are stapled at one end, What I am aksing is if anyone has had a simular issue were the middle pages do not move down with the rest of the pages to be stapled in the middle, The images in the pages are some heav coverage graphs, I am feeling it is a static build up and this makes the pages stick to the metal guide plate.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: BH C452 J72-26 Booklet Folding
    check the condition of the foam rollers in the finisher and also check the adjustments on the alignment section of the saddle sticher.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • Itsthepaper
      Supervisor
      • Dec 2007
      • 91
      Problems like that always have something to do with pages catching on the way down in the staging section, before stapling or folding. Also stapler section could be hitting the staged pages and pushing it away from the stack. Even if the problem is intermittent you could still cheat the door and carefully watch the sheets falling down and if it doesn't jam on you you could get a clue by watching, look for pages not dropping smoothly or pages moving as the stapler is moving.
      Love the Job Love the Work.
      • MAD0RAM
        • Oct 2012
        • 81
        Also check for buildup of dirt/toner on the static eliminators.
        The little hair like things.
