I cant figure out how to turn off the HDD, I keep getting and HDD error. I need to shut it off. Anyone know how?
How to turn off HDD on 7145
random
Removing the HDD for analysis of an abnormality and then reinstalling it after turning on and off the power may result in no recognition of the HDD.To avoid a conditon like this, condust this setting.
PROCEDURE
1. Enter the 47 Mode
2. "47 mode setting screen"
Press the no. of sheets setting button to enter "15".Check to see if "015-000" is displayed in the message display column.
3. Press the * button
4. Press the no. of sheets setting button to enter "97"
Check to see if "015-097" is displayed in the message display column.
5. Press the 'START' key
6. Press the 'STOP' key to terminate the setting.
7. To end 47 mode turn the SW2 OFF.
Note
When the data is in nonconformity, an error may occur, in this case, execute the format ( key operator mode)Comment
