Bizhub 501 bootup screen
  • tmathiou
    • Aug 2011
    • 18
    [Misc] Bizhub 501 bootup screen
    Hi All,
    Can anyonehelp me out?
    we got one OceVarioLink 5022 machine ( Konica Minolta Bizhub 501), in this machinethe bootup screen is different from bizhub series (only planets).
    I upgradedto the latest firmware version but nothing change in bootup screen logo
    How can I change in to Konica-Minolta boot upscreen logo ?
    Thanks in advance
  • ineo+6501
    • Mar 2010
    • 262
    Re: Bizhub 501 bootup screen
    Why would you want to If it's an Oce machine?
    • tmathiou
      • Aug 2011
      • 18
      Oce VarioLink 5022 is actualy a Konica Minolta bizhub 501.
      We have the Konica Minolta Pagescope Enterprice Suite but unfortunately does not working with Variolink.
      • ineo+6501
        • Mar 2010
        • 262
        Fair enough. You need to enter service mode, system 2, dip SW, change the correct switch to show the OEM screen and print engine in the config page.
        • tmathiou
          • Aug 2011
          • 18
          Ok i understand that.
          The problem is that the service manual does not mention dipSW for the OEM screen.
          • methogod
            • Dec 2008
            • 915
            I use Variolink toner on my KM all the time, they key the toner differnt - its easy to convert.
            To change the Configuration Page header to Konica Minolta bizhub, please perform the following:
            1. Access the Service Mode.
            2. Select System 2.
            3. Select Software Switch Setting.
            4. Enter Switch No. "10".
            5. Bin Assignment "00000000".
            6. Hex Assignment "02".
            7. Click on Fix.
            8. Click on End.
            9. Power the MFP OFF/ON.
            10. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
            • tmathiou
              • Aug 2011
              • 18
              This procedure is for color machines. Μust be a corresponding process for black and white machines.
              • methogod
                • Dec 2008
                • 915
                came from solutions with 501 in info... Check dip switch, check, reset, if no change put back...
                here it is....
                Products
                Products:
                bizhub C450P
                bizhub C450
                bizhub C252P
                bizhub C252
                bizhub C250P
                bizhub C250
                bizhub C352P
                bizhub C650
                bizhub C550
                bizhub C451
                bizhub C353P
                bizhub C353
                bizhub C253
                bizhub C203
                bizhub C360
                bizhub C280
                bizhub C220
                bizhub C652
                bizhub C652DS
                bizhub C552
                bizhub C552DS
                bizhub C452
                bizhub 751
                bizhub 601
                bizhub 501
                bizhub 421
                bizhub 361
                bizhub 423
                bizhub 363
                bizhub 283
                bizhub 223
                bizhub 652
                bizhub 552
                bizhub C754
                bizhub C654
                bizhub C351
                bizhub C352
                bizhub C300 Options:
                None Specified
                Details
                Subject:
                No Konica Minolta logo at power up ("Planets" only), Configuration Page header is printing as Generic and printer driver fails when trying to acquire the device information.
                • tmathiou
                  • Aug 2011
                  • 18
                  This is Solution ID:TAUS0701329EN*. I've tried without success. Do you have any other suggestions?
                  • ineo+6501
                    • Mar 2010
                    • 262
                    I've noticed within system 2 on the 501 a button called "OEM" which has a on or off setting. Don't know what that does as there is no description in the manual.
                    • tmathiou
                      • Aug 2011
                      • 18
                      The problem is that in our particular machine does not exist oem button. Must be a dipsw to enable, but do not know which.
                      • tmathiou
                        • Aug 2011
                        • 18
                        any ideas? somebody?
                        • methogod
                          • Dec 2008
                          • 915
                          This is right just tried it on a OCE version.
                          2. Select System 2.
                          7. Click on Fix. <--- make sure you press this if you press end it wont take....
                          8. Click on End.
                          9. Power the MFP OFF/ON. <--- make sure you wait 20 seconds - and turn off both sub and main power
                          • tmathiou
                            • Aug 2011
                            • 18
                            As I said earlier, this should be only for color machines. However i have tried. bizhub 501 default setting of dipsw 10. Bin Assignment "01000110" and not "00000000". Hex Assignment "46" and not "00". "Fix" buuton is "Set" button. "End" button" is "Exit" button. However i have tried Hex Assignment "02". Set instead of Fix. Exit instead of End. Power the MFP OFF/ON. But nothing. I wish to inform that I have done this process in a color machine, and it worked fine. Obviously we need another dipsw. Thanks.
                            • tmathiou
                              • Aug 2011
                              • 18
                              Solution ID TAUS0701329EN* Solution Usage 21
                              Description
                              No Konica Minolta logo at power up ("Planets" only), Configuration Page header is printing as Generic andp rinter driverfails when trying to acquire the device
                              information.
                              SolutionAdobe - Adobe Reader download - All versions .
                              SPECIAL NOTE : Solution contribution by Jim Behrends, Worgroup/SSD and Greg Lantowski/Ian Lynch/Mark D'Attilio/Cesar Jimenez, Production Print/SSD,
                              SPECIAL NOTE: Solution contribution by Dave Bruni, Workgroup/SSD
                              As can you see ONLY COLOR
