We have a bizhub 751 that just will not accept an I.P. address. It has the IC-208 installed in the machine (re-seated it too). The HDD is installed and formats just fine (shows as 100% available).
We ran the initialization of the Network Settings Data. We have tried DHCP to see if it would pull any I.P. address on its own and it never does.
I even tried turning OFF IPV6, AUTO DNS, LDAP and anything else I could find to turn off. If you manually plug in everything it DOES accept Subnet Mask, Default Gateway and 3 DNS's; but it will always blow away/indicate 0.0.0.0 for the I.P address. Help?
