meter reading
  • gabby
    • May 2011
    • 12
    [Misc] meter reading
    hello everyone, i have a problem with bizhub c252, meter count having a negative values and also the bypass tray cannot feed paper continuosly, during multiple printing, after it prints the first page, the machine ask to load a paper on the tray even though there are still paper left.... hope somebody can help me....
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: meter reading
    if im not mistaken, there's a bypass option and manual bypass option. manual implies customer is prompted to put in paper.
    • gabby
      • May 2011
      • 12
      Re: meter reading
      thanks for the reply jr2alta...
      how about the meter count?.., having a negative values.... can you give me a advice...
      • RRodgers
        • Jun 2009
        • 1947
        Re: meter reading
        I can,
        You have a BAD NVram and will need to get it replaced. ONLY KONICA CAN PROVIDE THIS for you. Even if you go thru a dealer the dealer has to go thru Konica.
