I have a personally owned Konica Bizhub C280 that the tray 3 (2,500 paper unit) had jammed. It made me disable the tray to continue printing. How would I go about re-enabling the tray?
BizHub C280 Tray 3 Disabled
Tags: None
Re: BizHub C280 Tray 3 Disabled
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com -
you just turn it off at the main switch (or unplug from the outlet), wait 10 seconds and turn it on to reset the temporary user initiated lock out.
if the tray cannot be opened the emergency open latch is via a hole on the rear of the large capacity tray. stick in something till you feel the lever, push it and the tray should open. If the tray for some reason (usually user error) has lifted all the way up and the drawer cannot open, well, your going to need a technician and an open checkbook.Comment
Edrick
I can try the power off for 10 seconds, the error I get though is C-0210Comment
Edrick
There's no doubt I'll have a tech come out soon, I just have to reactive our maintenance contract right now I'm working on downsizing costs as much as I can until spring. I've removed the paper, so that fault should clear if I power off the unit it's not something I need to go into the service mode and re-enable the tray?Comment
No, service mode is to allow tech to isolate sub sections..any error that displays *** is not available, continue operations?, followed by a request to turn off/on the sub power switch, will try to start working again when "MAIN" power is cycled. If it fails then you will be stuck in the loop until the problem is fixed...Sort of a "Limp along until tech arrives" mode. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
Edrick
