Need aftermarket Di2510 parts for the Imaging unit.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    [Misc] Need aftermarket Di2510 parts for the Imaging unit.
    Who can provide me with an aftermarket drum,blade & DS collars, possibly even a bag of DEV, though should be able to get that locally.
    Need to fix this machine on the cheap otherwise I'd be getting genuine parts via work. Its been asking for a replacement imaging unit for over a year now and its at 136% - print quality is now pretty bad, its still in use though.
    Please PM me with what you've got and we'll talk. (I only need the parts, I'm a long, long, long time tech)
  • methogod
    • Dec 2008
    • 922
    Re: Need aftermarket Di2510 parts for the Imaging unit.
    you can get drum after market kit with blade. (Less then $38)
    you don't want aftermarket DV though is this the same machine as the BIZHUB 250? then its cheap...
    total cost under $70 bucks.
    DRUM UNIT is still good, replace drum, blade and DV, takes whole 30 minutes with a vac, w/o a little longer.
