Toner Bizhub 250
  • farid latief
    • Aug 2025
    Toner Bizhub 250
    Is there an alternative to toner TN 211 (bizhub 250), for example, of the type dialta,
    mostly circulating in Indonesia is to type dialta
    tx before
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Toner Bizhub 250
    as far as I'm aware bizhub 250 toner and the toner that went into the earlier machines are totally incompatible.
    I've asked this question before as I personally know 3 people who own Di2510's and the genuine toner is no longer sold here, their only option is Katun, which surprisingly isn't causing any issues.
    • Hansoon
      • Sep 2007
      • 3389
      As said, absolutely incompatible. Don't even try. Aftermarket toner works for us good in these machines so Katun might be an option indeed.
      (Is that really ME promoting Katun here................?)
      Hans
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Hans
        Hey hansoon, do you sell those dev roller collars? Are they also suitable for the Di2510? Talk to me via PM if you want to sell some.
        • Hansoon
          • Sep 2007
          • 3389
          Collars are suitable for the whole series of machines starting with Di-200, 251, 350, 351, 2010, 3010, 3510, Bizhub B&W 200, 250, 350.
          You have a PM.
          Hans
          • farid latief
            thanks for the response
            I am sorry a few days on the way out of town
            hans ....
            frankly I still lay on "Katun"
            if only you can display the picture
            • Hansoon
              • Sep 2007
              • 3389
              Huh?
              Hans
              • farid latief
                Huh?
                Hans
                sorry for my english is not good
                I mean, that I do not understand about "Katun"
                real intention of "Katun"
                I really really do not know
                I hope you can understand
                I really hope a more detailed explanation of the "Katun"
                Thank you for your understanding because of my difficulties
                I translate it through google
                Thanks before Hans....
                • Hansoon
                  • Sep 2007
                  • 3389
                  Aaaahhhhh... now I got it. Didn't realize that you do not know.
                  Farid, Katun is a supplier of aftermarket spareparts and supplies for copiers. They are sometimes not liked because of their handling of reclamations when their products occasionally fail.
                  regards
                  Hans
                  • farid latief
                    thank you Hans...
                    for your patience to understand my language
                    so what steps should I do to overcome the scarcity of toner
                    so that the engine can keep the production
                    do i need to replace the existing spare part
                    • Hansoon
                      • Sep 2007
                      • 3389
                      Farid, your problem is not exactly clear to me. You asked for an alternative for the Bizhub B&W 350 toner. I'm sure you will be able to find with a search machine such as Google, suppliers for alternative or original toner in Indonesia.
                      (BTW: I realized that in your language Katun is the word for cotton.......... Hence the confusion perhaps. )
                      Hans
                      • KM7155
                        • Aug 2008
                        • 146
                        Hi Farid, i use the Di3510 toner in B350 before, the toner model if not mistaken is MT303.
                        • Hansoon
                          • Sep 2007
                          • 3389
                          I never dared to try but according to my information it is NOT compatible.
                          Hans
                          • farid latief
                            Hans
                            That's true "google translate"
                            thank you for the advice, but I would not take the risk, because many issues in Indonesia as it says Hans [I never dared to try but according to my information it is NOT compatible],
                            or there is a special setting after MT303 entered in B350 [KM7155] as you say
                            • KM7155
                              • Aug 2008
                              • 146
                              Hi Farid, nope, i just change the toner bottle and the machine printing happily.
