FK502 (C352) setting problem
  • KM7155
    • Aug 2008
    • 146
    Hi Guys,
    anyone face this problem before, setting the number of ring to receive fax is not working in the C352.
    set 8 rings, the machine pick up the incoming fax in 3 rings, set to 0 ring, still pick up in 3 rings.
    already reflash to latest firmware, still no help.
    appreciate if anybody can help.
  • methogod
    • Dec 2008
    • 921
    Re: FK502 (C352) setting problem
    make sure you have it on fax mode and not TAD or AUTO, where it picks up and will make the line ring if not a fax.
    but i have seen this when re-setting up a used machine.
    • KM7155
      • Aug 2008
      • 146
      thanks for the replied.
      where can i find the TAD and AUTO setting. my fax is working fine, just that i can't change the number of ring.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        you need to go into service mode and change the fax settings.
        I dont recall off the top of my head where it is, but its in the fax menu. You need to change the answer method from "timed" to "number of rings". Timed is the default setting (depending on marketing region/fax target) and ignores what you set in admin mode, once its set to "number of rings" you can use the settings in administrator mode to do what you desire.
        • methogod
          • Dec 2008
          • 921
          you can disable RX all together in FAX in service mode, but that is a work around... for a fucked board....
          but you want ADMINISTRATOR MENU (12345678 to log in), FAX SETTINGS, LINE PARAMETER.
          DIALING MODE SHOULD BE set to PB (works better)
          RX MODE SHOULD BE AUTO...
          THEN SET YOUR NUMBER OF RINGS, you wanted 3.
          My best guess... is the (PAGE 3 OPTION, scroll again and again...)
          LINE MONITOR IS SET TO "ON"...
          which always listens for incoming faxes, which need with some wacky systems like internal fax servers.
          I would see if that is on, first, if it is turn off and re-test, then verify the rest.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            The service mode setting of number of rings to answer versus answer after a predetermined number of seconds is the solution, i've had this issue in the past and this was the fix.
            the setting of choosing how many rings to answer in admin mode will do nothing at all and is totally ignored untill you change the above setting.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Here it is on my C253, it will be the same on the C352
              SERVICE MODE > FAX > NETWORK>
              Recieve signal detection mode: DEFAULT is "TIME" if you want to change how many seconds to answer, enter upto 15 seconds in the field below. IF YOU WANT THE ADMIN CHOICE OF HOW MANY RINGS TO ANSWER TO WORK, change to "No. of Times"
              IF FOR ANY REASON THE RINGS ARE NOT COMPATIBLE AND ARE NOT COUNTED PROPERLY LEAVE ON "TIME" AND SET THE NUMBER OF SECONDS INSTEAD.
              • KM7155
                • Aug 2008
                • 146
                [ATTACH=CONFIG]18869[/ATTACH]
                Thanks everyone for the input.
                Especially EarthKmTech, really appreciate ur effort for the pic. Save my day, problem solved.
