bizhub 920 pro
  • NEOTECH
    • Dec 2010
    • 69
    [Misc] bizhub 920 pro
    hi everyone i have a problem in adf for bizhub 920 pro sc 60-03 i replace adf board but now problem is when i make copy in adf paper was exit in adr try but adf motors still rotating and copy not come out i open copier side door machine will stop and i found paper there i cant under stand what happen with this machine. if any one have a idea plz help me.
  • RRodgers
    • Jun 2009
    • 1947
    Re: bizhub 920 pro
    Sounds like you missed a connector to me.
    • methogod
      • Dec 2008
      • 917
      Re: bizhub 920 pro
      I have brand new ADF units if you need one.
      • KM7155
        • Aug 2008
        • 145
        Re: bizhub 920 pro
        was the leading edge hit something? if not, i would bet the paper path sensor faulty.
        • methogod
          • Dec 2008
          • 917
          Re: bizhub 920 pro
          i would check i/o mode sensors on DF.
          also make sure its not a odd firmware issues, that may have been fixed in a later version. New-board may be old firmware.
          Re-seat cables, i would make a copy form the glass, make sure nothing is wrong anywhere else.
          When you replaced board, did you unplug from wall? i have seen weird stuff with older machines, when adding/replacing parts or consumables while power is on.
          • Mick01
            • Nov 2012
            • 362
            Re: bizhub 920 pro
            Did you do the ADF sensor sensitivity adjustment when you replaced the board? In the service manual there is a "List of Adjustment Items" when replacing a part. It outlines what adjustments need to be made and in what order.
            Hope this helps.
