KIP 700m Internal Counter Error
  • mojorolla
    The Wolf
    • 2609
    Machine is generating "Internal Counter Error". I have done the following so far:
    -check F1 fuse -OK
    -check for 24v - OK
    -check adjustment #753 set to zero - OK
    -I also tried the error masking but this did not work.
    -check error log. Counter error (e-0020) does not show in error log, found this odd.
    Machine is operating after service code is entered after error appears. I found a post regarding firmware on this model, but am looking for advice from those with more knowledge than myself. Is this a known issue with this model?
    Any help is greatly appreciated.
  • minimerlin
    • 851
    Re: KIP 700m Internal Counter Error
    I think you are on the wrong machine forum. I do not know of a KIP 700m in Konicaminolta range.
    Please do not PM me without asking first.
    • mojorolla
      The Wolf
      • 2609
      I am not sure about over the pond, but we get the manuals from the KM portal.
      Perhaps I will post under "other brands".
      Thanx
