Special Firmware Descriptions...?
  • Synaux
    • Mar 2012
    • 1224
    Is it just me or is the Konica site a mess?
    I count nearly 70 special firmwares and a mere 7 base firmwares for a c650.
    Unless one has memorized the differences between lets say the "GWW-R6" and the "GWP-6M" special firmwares, one is relegated to reading the PDF's for each firmware (which in my experience it tends to be a complete waste of time trying to find the correct needle in the numerous haystacks--much to my disappointment).
    I found a pdf from Konica that was pretty useful for the IC-409 for example (which had a brief description for each FW and their prereqs), but in the c650 section it was remarkably vague.
    Is there a chart or something with a quick breakdown of each special firmware?
    Thanks!
  • JustManuals
    • Jan 2006
    • 9838
    Re: Special Firmware Descriptions...?
    If there is a chart, I'd be interested in it too.
    Paul@justmanuals.com
    • JR2ALTA
      • Feb 2010
      • 2033
      You're preaching to the choir.
      Kyocera releases only the latest firmware.
      They basically call it version 1,2,3,4,5 and always include previous updates, so v.5 contains v.1-4
      Between 80 firmwares, codes for sensor checks, soft switches, hideous feed units and unstable boards you earn your chops as a Konica tech.
      I am trying my best to get back to a Kyo dealer before I completely burn out.
      • jotunn
        • 620
        That's nice, Konica Minolta got own vision of updates - they're releasing for example some firmware with 20 important bugfixes, but in the next released firmware there is only 15 of them included. So reporting problem to HQ, a month later there is a maintenace release with 3 missing bugfixes, so reporting again, then a month or two later there is next MR firmware with included next 2 bugfixes, but "magically" missing 5 other earlier buxfixes...
        According to my knowledge C224-C754 series is the last one with well known hardware/firmware philosophy, the next generation will be designed as a System on a Chip.
