C252 with no display
  • axyun
    • Aug 2007
    • 1323
    KM Bizhub C252 has no display. I turned off main switch and turned back on while holding utility key and display came on with image of hourglass but display went back off rather quickly. Did not get trouble reset screen. Any help is appreciated. Is this a PS issue. Frank/ActionPhotocopy
  • mmru4real
    • Aug 2008
    • 67
    Re: C252 with no display
    It is a known issue and there is an foc replacement for the touch panel, but you have to call ssd first
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      if you put a firmware card in the machine does it operate normal, ie, goto the firmware loading screen and allow the firmware to be loaded ?
      if so, this is NOT a control panel issue.
      • axyun
        • Aug 2007
        • 1323
        Thanks for the info guys. I have never done a firmware upgrade and am not aware of how the procedure is done. I go way back and have kind of stuck to the mechanics and go minimally involved with connectivity type problem. I used to service the rocks in the caveman days when there was double imaging and such from guys who chiseled stone and had double vision. I charged them double and they didn't know the difference.
        I would probably have to forfeit the call or get someone who can do it to go with me and pay him handsomely. The call is in brooklyn,ny. Any takers? GBA
        • badusha
          Kindly check the NVRAm
          • axyun
            • Aug 2007
            • 1323
            Thanks Badusha.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Thats what i was getting at
              because if the NVRAM is corrupt you can generally still load the firmware and experience a functional, fully illuminated control panel, which is a dead give away.
              • Synaux
                • Mar 2012
                • 1224
                If all else fails, you might be able to use the jig software to interface with it via comm port (use a null modem comm cable)...it works on a p252 (which has no physical display).
                Then, whoever is using the machine will have to use a laptop or something, but at least they can potentially use it until you get a solid fix. Basically this method creates a pseudo-screen interface via computer.
                Also, will the machine respond when you press the keys next to the screen after warm-up (e.g., copy button, etc)?
                If for nothing else, I want to know if the software would work...pm me if you need the software
                • axyun
                  • Aug 2007
                  • 1323
                  Thanks but you are talking to an exceedingly deficient tech when it comes to connectivity and the computer. Old school and never ventured passed very shallow waters of the newer technology. I realize it has gotten far more intertwined with the machines and will get even more so. I will have to get someone to assist and show me or forfeit certain calls. Frank
                  • bowser
                    • 25
                    check the condition of the m board by the powe supply on the left side of the machine
                    it could be bad
                    • axyun
                      • Aug 2007
                      • 1323
                      Thank you Bowser. Frank
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        Guys like you still have a place - no matter how complex things get on the I.T. side there will always be paper jams, technician consumables replacements and other mechanical issues that require addressing.
                        What service companies will want ultimately is for all techs to attain a certain minimal level of lets call it "I.T." knowledge so that when customers ask questions while your onsite they can be answered without involving another technician, which is a cost to the company. It's also beneficial to the company to be able to charge for work such as I.T. that is above and beyond the scope of the service contract. As copy costs drop continuously to unprofitable levels, the big players will depend more and more on service based revenue and contracted maintenance of software products etc. Love it or hate it, the I.T. side of things is here to stay and only going to continue to expand.
                        • axyun
                          • Aug 2007
                          • 1323
                          Thanks for the good message, Richard. Stay warm. Want to do a service call in Brooklyn,NY?
