C2558 error in Bizhub 164
  • amethyst30
    • Aug 2025
    [Error Code] C2558 error in Bizhub 164
    I have a problem on the error C2558 in Bizhub 164. I have changed the tcr sensor and OPC drum, still, after warming C2558 immediately appeared. I have closed and open the front door but C2558 kept on appearing. Do I have to change the developer powder?
    Thank you for any idea you may share with me.
    Sincerely,
    Amethyst30
  • humpty dumpty
    • 29
    Re: C2558 error in Bizhub 164
    You have to replace the dev and then run dev setup otherwise you will keep getting this code.
    cheers
    • juve
      • Dec 2012
      • 86
      Sincerely,
      Amethyst30
      i will first replace developer and do atdc adjustment (tcr)
      • amethyst30
        cheers
        Thank you for the reply. I followed your method and it worked well. As of now I am still using my bizhub 164.
        Amethyst30
