Konica Minolta C450
  • sulemandw
    • Sep 2011
    • 19
    Konica Minolta C450
    Hi friends
    how can we reset the fusing unit of C450??
  • mindhunter
    • May 2008
    • 146
    Re: Konica Minolta C450
    Originally posted by sulemandw
    Hi friends
    whats you exat meaning for reset ?
    did you mention to life indicator ?
    • sulemandw
      • Sep 2011
      • 19
      yes life ended
      • mindhunter
        • May 2008
        • 146
        yes life ended
        the easiest way is to cut the 2 green wire on fusing.(these cables are on the connector of fusing).
        then connect this 2 cable to each other with 1AMP Fuse .after the first copy you made . life will be clear.
        the second way is to reprogram the IC on the main Controller that has 8 leg or jumper via the programmer.
        I think you should do the first one
        • sulemandw
          • Sep 2011
          • 19
          thanks for solution
          you have c550 and c350 firmware
          if you have any firmware please send me
          • mindhunter
            • May 2008
            • 146
            thanks for solution
            no i dont have them .
            im searching for them tooo
            • sulemandw
              • Sep 2011
              • 19
              Good Luck
              but the c350 you told me that you already send but i did't receive
              • sulemandw
                • Sep 2011
                • 19
                Good Luck
                sorry c450
                • mindhunter
                  • May 2008
                  • 146
                  sorry c450
                  yeah check your spam list. if you didnt get them give me another email that I could forward it to you again .
                  • RRodgers
                    • Jun 2009
                    • 1947
                    1 amp fuse eh? Well if that doesn't work maybe just a 5 amp one.... hell.... just jumper in 110v LOL
                    (don't do ANY of that)
                    • JustManuals
                      • Jan 2006
                      • 9838
                      I have firmware for all of the K-M models. But like everything else, it isn't free. If interested, email me at Paul@justmanuals.com
                      • mindhunter
                        • May 2008
                        • 146
                        about fuse Ive tested a lot and we dont have any problem with it.seriously the first time I tought that was impossible.but If you wanna a image or movie I can give you.
                        about the copier that they are 110V we have a copy of 110V IC that is RAW.so again no problem.
                        yeah I knew it . its not formal and legal but many people in developing country do such things.
                        And also I remember another way that is : Makes your Copier NON-STOP and Makes off your life-indicator Alarm.
                        • sulemandw
                          • Sep 2011
                          • 19
                          thanks its worked
                          Now an other problem with yellow image unit i changed 4 unit but after 60, 70 copies yellow line on the edge of the paper with copies the line is coming more and more high any solution
                          • sulemandw
                            • Sep 2011
                            • 19
                            no i did't received the email please send me on this sulemandw@yahoo.com
                            • sbus
                              Due to the shortage of fusers (which come from Thailand; there was a flood in 2012 that disrupted fuser availability), KM released a firmware ("special firmware" on the KMBS download site) that, believe it or not, resets the fuser counter when it reaches the end, to allow people to keep using their old fuser when none were available. It's still there, and still downloadable... and you ain't gotta cut any wires... It's for the K0 firmware release I believe... The download (and a ReadMe file) is available from Support & Drivers Search Page | Konica Minolta Business Solutions, U.S.A., Inc.. Select "Color Products" then "Bizhub C450" then "Special Firmware"... click "Show" and you'll be on the special firmware page. The fuser counter firmware is GYC-K0... (Full disclosure: I read the ReadMe but did NOT yet install it...)
