C250 scan to smb
  • keneisman
    • Jul 2025
    C250 scan to smb
    I've searched for, found and followed everything I could find on the subject of setting up the C250 to scan to smb. I can't get mine to work. I can successfully scan from other KM copiers to the same share, so I know that's set up right. I've compared the scanning and network settings of this copier with the other copier that works. They look the same. I'm just getting a very vague error message saying that it can't connect to the network. But i can print to it over the network and get into pagescope without a problem. So, I'm thinking it's connected to the network ok. Any suggestions on what I can look for to help me figure this out?
    Ken
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C250 scan to smb
    Ken
    if all the settings are correct, the number 1 problem with smb scanning on the c252/c250 that still catches people out to this day is that the the computer name must be all capitals in the one touch key. (or you can use its IP address, IF the computer has a static IP)
    • keneisman
      Yeah, it's all caps. I also tried it by IP address. It still doesn't work.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        check the ntlm settings are set for v1/v2. I am not sure the c250 can do this but that may be what is needed.
        Also what o/s are you scanning to?
        • keneisman
          It was originally set to V1/V2. I changed it to just V1 to see if that would fix it. It did not.
          I'm scanning to a Linux-based NAS running CIFS for sharing.
          I've got a bizhub 501 scanning successfully to the exact same share.
          • emujo
            • Jun 2009
            • 3009
            Note
            • keneisman
              Originally posted by emujo
              Note
              Aah! 2a is the culprit for me. My file share is across a router from the C250! I don't suppose there is a newer version of firmware out? I wouldn't even know how to check the current version or upgrade it, anyway.
              Thanks for all your help.
