C250 with Fax Kit freezes when sending fax
  • mrwho
    Major Asshole!
    • 4299
    [Misc] C250 with Fax Kit freezes when sending fax
    The machine scans the document to be sent by fax and then the panel freezes (if I open the front door it will aknowledge it).
    I'm visiting the customer today, and I'll try the usual (firmware update, nvram restore, the works).
    What I'd like to know is this: has this ever happen to you and how (and if) did you fix it?
    Cheers!
    Mascan42
    Ibid
  • mrwho
    Major Asshole!
    • 4299
    Re: C250 with Fax Kit freezes when sending fax
    Solved.
    Tried firmware update to no avail.
    Then noticed the fax target (on the marketing area) was on JP instead of EU. Also the HDD was disabled. Solved those two, rebooted the machine and fax now works.
    Thanks to all who took the time to read this.
    Cheers!
    Mascan42
    Ibid
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      that must of been the first time they ever tried using it as it never would of worked like that.
      How did the hdd get turned off and why was the fax target set to japan - was a data clear or nvram initialize done recently ?
      those settings dont just change by them selves.
      • mo0651
        • 1054
        It is a c250.......anything can happen!
        • mrwho
          Major Asshole!
          • 4299
          Yup, it was an NVRAM restore.
          Mascan42
          Ibid
