BizHub 500 Lockup
  • jamacdon
    • Jun 2025
    BizHub 500 Lockup
    I have 4 BizHub 500 systems and intermittently one of them will completely lockup. The console is somewhat operational and the current job status is set as "Deleting" however nothing ever happens. We have waited over 24 hours for the job to be deleted.
    The web interface is accessible and the machine appears to look as though nothing is wrong with it. When we try to delete the locked job (which is already flagged as "Deleting") or any other job it just flags the job as deleting.
    Sometimes all jobs will show as "Printing" instead of "Deleting".
    The only way to recover from this is to cycle power which causes us to loose 15-20 jobs in the queue.
    We have had this problem for about two years and have not been able to track anything down as to what is causing it.
    Any help would be greatly appreciated.
    Thank you
  • konisolver
    System Engineer
    • Oct 2007
    • 137
    What firmware level? If you are using version 31 and printing from Adobe 8 there is a bug with the Visual PS driver. Update the unit to 31GUP and PsVisual to 310.
    • Juggy
      Technical Support
      • Sep 2007
      • 101
      If you have a HDD installed try replacing with a new one. We had similar problem in a Bizhub 350 the machine used to freeze and we needed to power off and on to restart.
      • jamacdon
        The MFP Controller reports 50GA-0100-GUP-31-000 and using PCL Driver 3.01.00.00.
        We do use Adobe however many times when it locks up it can be from a print job (word, outlook, adobe) or a copy job as well.
        • jamacdon
          This sounds like a possible solution however we have 4 systems and they all seem to freeze up. Do you think it could possibly a specific hard drive model or batch even?
          On a side note we also have 2 BizHub 600's that do the exact same jobs and have never locked up.
          • redhawkpath
            This is definately a firmware issus. Try upping the firmware to the latest version.
            Hard Drive Next, but first the firmware.
            • redhotrob
              • 69
              At least with having more then one machine, only one with the problem, you can print off all the user and service setting to see if there is anything odd with that one.
              And if you were to try a hard drive you could swap from one machine to the other.
              • jamacdon
                Actually they all have the lockup issue. It is not isolated to one machine.
                Someone mentioned to me that it could be faulty or bad networking equipment. I can't see this being the case as we have various technologies on our net ranging from linux boxes to voip systems and nothing else has a problem.
                • Scott_Lewis
                  • Mar 2007
                  • 519
                  Take note of which PC/user is at the top of the print queue when the controller locks up. It could be a single mangled computer sending garbage to the copier. He locks one up, then moves on to another.
                  • ITCHYFINGER
                    Thank you
                    I AGREE WITH THE HARD DRIVE REPLACEMENT. I HAVE HAD SEVERAL 200'S AND A 350 LOCK UP SOLID AS WELL A 600. EVERY TIME THE FIX WAS REPLACING THE HARD DRIVE.
                    • mitchl
                      • Apr 2007
                      • 501
                      Has anyone else noticed that there's something about a copier that just pisses a HDD off to the max? I have never seen so many bad hard drives in my life since they started using them in copiers, I wonder if it doesn't have something to do with vibration or something along those lines or is it that they are made in China and other less than quality oriented locales?
                      By the way has anyone done any searching in the knowledge base for similar probs and fixes, if so what did you find? I'm sure if everyone here has seen the problem they must be recommending something or at least one would assume.
                      • pepper38_cnd
                        Field Service Manager
                        • Aug 2005
                        • 1075
                        Just out of curiosity are the machines that are locking up setup to require access codes to copy and print?
                        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                        Now into Ip TV KODI Boxes
                        • jamacdon
                          When your systems would lock up, was the console still operational? Could you still ping the machine and would it still accept jobs? I have been thinking about the hard drive issue and not sure if that would affect the entire operation of the machine or just the job processing.
                          I almost seems as though the entire machine is working fine except it has gone into a loop trying to cleanup after processing a job.
                          • pepper38_cnd
                            • Aug 2005
                            • 1075
                            You didn't answer my question about access codes?
                            The reason I asked is because I have seen exactly what you are describing happen on some other machines when a person tries to delete a print job without entering the access code of the person who sent the print job. The que says deleting and the only way to reset is to power off. This is a firmware issue the machine should say access denied, and continue printing.
                            • jamacdon
                              They do not require access codes on hte machine itself however there is a 3rd party device used to lock/unlock the machine. We have tried operating without this device hooked up and it still locks up.
