Isw tool c6500
+ More Options
Posts
  • beano
    • 54
    [Misc] Isw tool c6500
    I have isw 3.81 e verison loaded my laptop win 7 64 bit it wont load the usb driver when usboua cable the cable is good anyone else have any ideals I reinstall it 3times
  • methogod
    • Dec 2008
    • 921
    Re: Isw tool c6500
    YOU NEED THE 64BIT DRIVER...
    OR USE THE USB STICK TO LOAD - UNLESS YOU PREFER TO LOAD BY USB THUMB DRIVE.
    only reason you need isw is if you replaceed a main board...
    good luck if you need help msg me i can send it to you or walk you through ti
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Re: Isw tool c6500
      Usb thumb drive is easiest (in the manual)
      If you need to use the laptop you will need to boot the laptop into the "digital driver signing not required" mode (or some such nonsense) the Usb driver used by the iswtrns program is not signed and supported by Microsoft and Windows 7 under normal mode will not let it run.
      • methogod
        • Dec 2008
        • 921
        Re: Isw tool c6500
        reboot pressing F8, select "run with out driver signage or something like that" connect your USB cable to the C6500/01, and wait till windows finds the USB controller hub, its going to pop up in red saying its not signed do you want to continue... select yes.
        you should be good.
        just remember ever time you reboot you have to do the F8 selection to connect to the MPF, or it wont allow the unsigned driver to be allowed to start/installed.
        I know you would think there should be a easy way to turn it off. but i don't know of any of the top of my head.
        • kronical
          Kronic Copier Ninja
          • Nov 2009
          • 230
          Re: Isw tool c6500
          Sorry to say, but this is incorrect. Windows 7 works just fine with even the old ISW tools. The problem here is that the ISW tool does not contain a 64-bit USB driver for the 64-bit OS. You absolutely must have a 32-bit OS to use ISW.
