Bizhub C450 scan to Email or Folder multiple pages Problem
  • kamalwasti
    • Jun 2025
    HI Guyz..
    We have Konica Minolta Bizhub C450 Machine. When we do 2 pages to SCAN to EMAIL or SCAN to FOLDER. It creates 2 different files. Out requirement is that we need only one file with multiple scan pages. Does anyone have any idea how it can configure. I have attached the configuration as well for the reference.
    I tried to configure Separate Scan - OFF and ON. But same result.
    During Surfing the forum, i came to know to enable Storage / HDD. I would like to know where I will find this option.
    Regards
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Bizhub C450 scan to Email or Folder multiple pages Problem
    first question;
    Are you an end user of this machine, or the servicing technician?
    If you are the end user, please refer to your operations manual or call a trained technician.
    If you are the technician and you don't have the proper manuals then contact manuals4you, as he will be able to assist you with a request for service documentation.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • TheOwl
      • Nov 2008
      • 1732
      You must have the HDD option fitted to your machine to be able to scan multiple pages into a single file. No HDD, no multi-page scanning.
      • kamalwasti
        Thanks for your reply.
        Does it require any special Hard Drive or we can install any Desktop or Laptop PC hard drive. What does it call?
        • TheOwl
          • Nov 2008
          • 1732
          From my experience, if you don't know what sort of HDD, then you are not going to know that the HDD also has to be enabled in service mode.
          I would suggest that you get in a tech to fit the HDD off for you and make sure that everything is working.
          • kamalwasti
            Dear Owl
            Thank you very much for all your valueable comments, now atleast i know what i need to check. I ll give a shot and keep you update.
            Regards
            Kamal
