I've been having problems from users stating that printing takes a really long time. 30-40 pages take about 15-30 minutes, sometimes even longer. I currently have the Universal Print driver installed as the driver. Would the VXL drivers from Konica be faster?
Best Driver for Bizhub 350/200
Re: Best Driver for Bizhub 350/200
I assume network connected, are they printing direct or through a server queue? -
Try sending the same job to an older HP 4/5..if the job processes quickly, then change the driver to the PS (VPS).. You are sending PS files and the PCL driver has a rough time converting them...We had one where the properties tab stated that the file was 24kb..If you watch the job spool in the queue, it would actually be about 5-6 meg as is processed. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
PDF's print best using Postscript (VPS) but shouldn't have a problem with VXL(PCL) drivers. However, what kind of content are in these PDF's? What version of Acrobat are they using? I have seen issues with Acrobat X and heavily graphic intensive files taking massive amounts of time to process.Comment
I changed the drivers back to VPS and also, I unchecked collate. The pdf's print much faster from Adobe now.Comment
