Print Head Unit Bizhub C353
  • ccspolska
    • Jul 2008
    • 25
    Hi,
    Did anybody knows there are any differences between print head unit in BH C253 and BH C353. Parts Guide says two differet part numbers. Could I use one from BH C253 and install in BH C353?
    Kondi
  • jotunn
    • 640
    Re: Print Head Unit Bizhub C353
    They are different because of higher clock rate given by PWB-MFP in C353 - so you can't use them alternatively.
    • mo0651
      • 1054
      They are the same as magicolor 8650
      • jotunn
        • 640
        Yup, just because this is C353 without scanner.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          they fit and they will work, the question is for how long.
          the polygon motors in the C253 PH units are not certified for the extra RPM's required for operation in a c353.
          • wseyller
            • Sep 2012
            • 1129
            Sounds like it could be done to get a down machine up and running temporarily until you get the correct part in.
            Sent from my Galaxy Nexus using Tapatalk 2
