Bizhub 750- Code 2401.
Is there anyone who has solved this code? Because the opinions are different:
- an Open ICP6 on the PRCB. the ICP is a fuse that looks like a resistor on the board. it will blow if there is a bind in the tray 3 lift motor.
- the erase lamp is unconnected
- a bind in the drum unit can also cause this code.
- There`s a mistake in the manual c2401 and c2301 have been swapped over. 2401 relates to a disconnected E.L. lamp. Here`s a couple of solutions you can try.
C-2401 at power up.
Solution
CAUSE: C-2401 normally indicates a failed erase lamp, although it is caused, in this case, by a bind in the drum carriage.
SOLUTION: Remove and inspect the drum carriage assembly. Run the Toner Cartridge Set mode as well as the Developer unit/Drum.
