bizhub 20 presets
  • brent
    • Nov 2008
    • 1212
    bizhub 20 presets
    so this bizhub 20 is out and new. but the default screen is fax. is there any way to make it defaulted to just copy? I can not see anywhere in the menu to switch. its just kind of annoying how customer has to always put it to copy if they are only using it as a copier. any thoughts?
    thanks all
    brent
  • JR2ALTA
    • Feb 2010
    • 2033
    i think it just stays where you leave it
    • scottybbb
      • Dec 2010
      • 126
      Re: bizhub 20 presets
      Under general set-up set mode timer to off.When first powered on it will go to fax mode as default but once copy button is pressed it will stay there until powered off.
