Earlier I had KM Bizhub C220 and in that machine With the new version of FW G00-C2 and above it is possible to disable the end of life message for consumables.
Now I have KM BizHub C224 and I want to do the same thing with this machine..
Can anybody give me the firmware for that..
It worked great in C220 by disabling the end of life message.. Best part is You dont have to open up the copier to remove the chip and then resseting it and then put it back... the procedure is much simplier, just update the firmware, go to settings change the values and BINGO!!!! Machine is unlocked...
