Konica Minolta Bizhub C451 Service Mode
  • Oscar57
    • 79
    Does anyone know the Service Code to get into Service Mode. It would be greatly appreciated.
  • beano
    • 54
    counter button stop 0 stop 0,1
    • Scott_Lewis
      • Mar 2007
      • 519
      Close, but no cigar.
      • ck1
        • 485
        just like the C252 352 . UTILITY COUNTER detail s 0 0 s o 1
        • Oscar57
          • 79
          Thank You!!!
          • crazyforcomputers
            So very close!
            You are getting very close, but that should not get you into service mode. You are getting very, very close though!
            • mrobe48942
              • 13
              Utility counterkey
              Check details
              stop key
              00
              stop key
              01
              • rrrohan
                • Sep 2011
                • 1977
                Re: Konica Minolta Bizhub C451 Service Mode
                unless this is a machine your own company ran up they probably changed and enabled the CE Authentication so even if you get in service mode you may be asked for a password
                • manoj1686
                  • Jan 2011
                  • 22
                  Then what is that password Mr. RRohan, since I am facing the same problem with a BZ C451
                  • solidzdawg
                    • 71
                    Try 92729272 for the additional password
                    • dhaneshumarekn
                      utility
                      meter count
                      stop
                      00
                      stop
                      01
                      • paricutin
                        is 92729272
                        • venluckey
                          • Mar 2016
                          • 36
                          utility
                          meter count
                          Check Details (if it has it)
                          stop
                          00
                          stop
                          01
                          Password is 9272 x 2 or x 4 i have seen some machines have it set to 4 times being put in, looks like this
                          9272
                          927292729272
                          optionally you can turn this off also
                          • jek308
                            I'm having the same problem with my C308......92729272 DOES NOT WORK! HELP!
                            • jek308
                              try 9272x4
