Working with spot colours bizhub c8000 with CW5
  • AB1984
    • Oct 2012
    • 64
    Hey all,
    We're just trying to get to grips with working with spot colours from inside command workstation 5 (specifically on the KM bizhub c8000). We're basically doing it by trial and error at the moment, we've had a little success, but just hit a road bump where, on the last run, the spot colours Would output, but only at 100% the places where it was less than 100% just didn't print at all. If anyone can help with this particular problem, I'd be grateful, but would be even more grateful if someone could point me in the towards a good tutorial or something that would cover everything.
    Cheers
  • Texers
    • Apr 2012
    • 43
    Re: Working with spot colours bizhub c8000 with CW5
    hi,
    if you haven't tried it yet.. i would suggest to go www.efi.com/forums
    there is a fantastic amount of info in there..however you may need to comb through to find your answers.
    and to your particular problem could use bit more info..
