After i change the developer, i make the ATDC sensor gain (without the toner bottle). The problem is that the gain is too high, 163. The machine does like 6 or 7k copies and enters the error c3557. Meaning it needs to change the developer again. I don't know where i'm wrong, or what doesn't work properly. Any ideas?
Bizhub350 Developer problem
Re: Bizhub350 Developer problem
are you doing this as part of drum replacerment ?
if so, triple check that the relevent counters have reset, and power off the machine and check once more before running f8. Its not uncommon to have to reset the drum counter on these things 4 or more times before it resets for some unknown reason. -
if so, triple check that the relevent counters have reset, and power off the machine and check once more before running f8. Its not uncommon to have to reset the drum counter on these things 4 or more times before it resets for some unknown reason.Comment
You MUST install new drum kit and developer at the same time. Open duplex door before powering on so the C2557 won't appear before you can reset the PC counter and then run the F-8. It's best to reset the PC counter, then power off and rebuild the unit. That should do it. These machines and there predecessors (Di2010 series) never handled the F-8 adjustment well. Also, make sure you are using the DV310 developer and not the developer for the 2010 series.Comment
You MUST install new drum kit and developer at the same time. Open duplex door before powering on so the C2557 won't appear before you can reset the PC counter and then run the F-8. It's best to reset the PC counter, then power off and rebuild the unit. That should do it. These machines and there predecessors (Di2010 series) never handled the F-8 adjustment well. Also, make sure you are using the DV310 developer and not the developer for the 2010 series.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
The problem may be the solenoid that turns the toner bottle and the hopper unit, over the time the sponge that has the solenoid becomes like glue, for this reason the toner bottle or the hopper unit is always turning and adding toner to the developing unit, ( also when you are doing a f8) and after the reparation you can obtain this error code. Check it please!Comment
Ies, i did all that when i changed the developer. I checked, it is DV310, i checked to make sure that the counters are reset. Still the machine wont do more than 7k copies with brand new developer. I cant figure what the problem is. could it be the toner i use or the ATDC?a machine is only as good as your tech : source:screwtape ; the scary oneComment
I haven't changed any ATDC sensor in this model but may be of course, in my opinion de problem are the solenoids, there are two, one for the toner bottle and other for the toner hopper, when they start failing the problem is not continuous, anyway is not a bad idea to check it because you'll need to do it later or sooner. If you client uses an original toner it can't be the problem but if your client has recharging it....Comment
