BH362 Print Meter Reading
  • k130
    • Oct 2011
    • 36
    Hi
    I have a problem with this machine. I try to print the meter reading but the machine ask a letter size paper after I changed the MFBS.
    I have set the default paper is A4. Also in the MFP menu. And everywhere else that need to be set as A4. I test to print the demo page. No problem
    But it just cant print out the meter reading and setting list. I'm stuck.
    Later I found out the the machine detect A3 paper when I closed the radf. I do the original detection turn to yes and f7-1. Switch off. And fail again. Please help.
  • dallas
    • Jun 2008
    • 115
    Re: BH362 Print Meter Reading
    - MFBS: Did you set the CPU frequency right?
    - Original Detection: Check the DF actuator switch at the back of the glass.
    • TheOwl
      • Nov 2008
      • 1732
      Did you set the "Marketing Area" with in Tech Rep Mode?
