konica minolta biz-hub c6500 2451-2454 errors
  • Mick01
    • Nov 2012
    • 362
    #16
    Re: konica minolta biz-hub c6500 2451-2454 errors
    HI,
    I dont believe any one had suggested the charge corona units yet. Make sure they are seated correctly.
    i did have one machine that had a faulty laser write unit. It was continually writing so was discharging the drum.
    Try swapping the colour laser units around (black laser is different). See if the fault moves with the laser unit.
    • ihatetoner
      #17
      Originally posted by spacecadet
      hi all
      i have a c6500 and i keep getting error c2451 up to c 2454 error codes as well as c2411 and 2401 i have replaced the
      developer
      tcr sensors
      check the developer drive motor
      and checked the print board
      is there anyone who can help me to get past these error codes so i may get printing again..
      the zimbo tech
      I've had this problem before. I tracked it down to a faulty toner level sensor in the toner hopper. The hopper was bone dry but the machine thought it was full and kept trying to dump toner into the developer then would throw the c-2454 code.
      • yomba
        • Jul 2012
        • 37
        #18
        i am having a similar problem. the machine codes out with a 2454 at boot up. i swithed the the developers (as per tech pub) the code followed the developer. before i could read the ymc toner densities in the service mode. now i cannot read the density of none. I have not changed the black developer yet. i am more inclined to a failed tcr sensor. any advice?
