KM 350 service codes
  • Happy Howard
    I need the codes to set developer and new drum install and where is the service switch to put yhe codes in at on this copier. Also is there any thing else I need to do when installing the above stuff. Thank you for the info.
  • wseyller
    • Sep 2012
    • 1129
    You have to reset the counter in service mode and turn off copier before installing new drum and dev. Then after installing you go into service mode and then function and then run F8. I recommend you get a manual. This machine is picky and if you do it wrong the will get a c2557 error when the atdc sensor doesnt read a good toner/Dev mixture.
    Sent from my Galaxy Nexus using Tapatalk 2
    • Hansoon
      • Sep 2007
      • 3347
      Re: KM 350 service codes
      Get a tech. This not something an end user can do.
      Hans
      “ Sent from my Intel 80286 using MS-DOS 2.0
      https://www.copytechnet.com/images/smilies/biggrin.png
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • minimerlin
          • 851
          And hello to you ! How about introducing yourself?
          Please do not PM me without asking first.
