Konica 7145-Frequent jamming on UPPER FIXING ROLLER
  • legaspiclg
    • Oct 2011
    • 72
    [Jamming] Konica 7145-Frequent jamming on UPPER FIXING ROLLER
    hI,
    I have a Konica 7145, that keeps jamming on the Upper Fixing Roller, i tried to replace my other 2 used Fixing unit but still the same problem occurs. Is there any adjustments on the machine?
    Please help.
    Regards.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica 7145-Frequent jamming on UPPER FIXING ROLLER
    Paul@justmanuals.com
    • nmfaxman
      • 1702
      Copy something output face up.
      If it doesn't jam, the problem is the sponge roller in the turnaround section.
      If it still jams, check claws and web unit. I have also seen a bad press roller or lack of pressure cause this.
      • tech51
        • 846
        Originally posted by legaspiclg
        hI,
        Please help.
        Regards.
        May be a dumb question, but if you've put different fusers in and it still jams, are the rollers rotating? I remember the drive gear could fail on these machines causing exactly this problem......
        • SmellsHot
          Head Tech
          • 512
          whats the jam code your getting? Sounds like exit sensor is broken/missing.....
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • pepper38_cnd
            Field Service Manager
            • Aug 2005
            • 1075
            The little tiny star rollers on the drum carriage get gummed up with toner and stop turning catching the lead edge of the page before entering the fuser. Just pull off the star rollers and test.
            Now into Ip TV KODI Boxes
            • RRodgers
              • Jun 2009
              • 1947
              Was this the model with the bushing that would go bad for the fuse drive gear, and was a PAIN to fix because you had to take out the main board just to get at it?
              Pull the fuser out and see if the shaft that holds the fuser drive gear moves up and down at all.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                back in the bad old days when these peices of crap were still supported in my country, I recall having the solenoid driven gate above the fusing unit having issues. If the paper is crashing into it, check it, the problem may not be the fuser at all.
                I've also had to replace that sponge roller that's been talked about, from memory that was used when duplexing as a decurling roller. It was a collossal pain in the butt to change and eventually the sponge degraded to the point it became a sticky twisted roll of tar.
