B751 Strange copy problem
  • jimmyjwc
    • Jun 2011
    • 7
    I've got 2 B751's with a strange copy problem. If you do a run of about 10 or more copies, randomly the image gets cut in half. This happens no matter what mode you use eg. booklet, duplex, 4in1. v.20 firmware loaded
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: B751 Strange copy problem
    presumably off the glass ?
    if so, leaving the machine to make its own descisions will result in this behaviour.
    Tell it exactly what you want and it shouldnt do it. IE, the original size. Auto detection seems a bit crap on these machines off the glass.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Never seen it before, but I think it would be the print control board.
      • mo0651
        • 1054
        Did you reflash firmware. I thought it was up around version 30. Have not looked tho.
