Faxing from PC - C253
  • joneze
    • Aug 2007
    • 128
    Hello,
    I know on the old kit c450, 250...etc you used to be able to fax from the driver. But in the new range there is no fax option for this and there is no fax installed option in the configuration of the mfp in the driver either.
    Am i missing something here? or is there some other software that i can download to fax from pc?
    Many Thanks
    Mark
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    There is a separate fax print driver. It does not auto load when you run the CD but it is on the CD that comes with the machine.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
