Minolta di-1610
  • Destoned
    • Jul 2009
    • 24
    Minolta di-1610
    I trying to find a gdi driver for this product a hp compatible driver.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Minolta di-1610
    No drivers here, look elsewhere.
    • kronical
      Kronic Copier Ninja
      • Nov 2009
      • 230
      Re: Minolta di-1610
      Ya know, you COULD try KONICA MINOLTA Global since, ya know, they made the thing.
      • Destoned
        • Jul 2009
        • 24
        Re: Minolta di-1610
        I work for a KonicaMinolta dealer and have access to all the drivers but there is no Di-1610 windows 64 bit driver. I was hoping for a compatible gdi driver as we found some hp drivers for other models in the past.Thought maybe someone had encountered a driver that would work. Its all to help out a few customer who changed their PC's and would like to print to this unit.
        • Hansoon
          • Sep 2007
          • 3389
          Re: Minolta di-1610
          There's a W7 64bit driver for the BH-162 which is an almost identical machine.
          Here is a workaround I found on the Internet some time ago:
          "How To - Get around installing 32Bit Drivers on a 64Bit System
          Time for another how to as I have come across this one a few times lately and that is how
          to install 32Bit driver on 64Bit systems when you get the message to "Please insert the x86
          Media" or "Could not find ntprint.inf for x86" dialog boxes. Typically you would get this
          message when you go to Printer Properties > Sharing > Additional Drivers > x86 > Pointed to
          the 32Bit driver > error.
          The scenario that I am going to use is within a Domain where you are trying to install 64
          and 32Bit drivers onto the server which you will then share out the print queue so that all
          computers are covered.
          When you come across this error, you may need the help of the IT people, or a customer
          that knows either the "Domain Admin" or "Administrator" logon credentials. If you know what
          you are doing, then you could also create a new user and add them to either of these groups.
          1. Logon on to a 32Bit PC
          2. Install the 32Bit Driver (doesn't actually have to have the port setup correctly, LPT1 will
          do)
          3. Start > Run
          4. \\<servername> (where the print queue is installed)
          5. Printer Properties if on a 2008 Server or Printers and Faxes > Printer Properties on a
          2003 box.
          6. Sharing
          7. Addidtional Drivers
          8. x86
          You should now see that the drivers are being copied to the server. Once this is done, you
          can then delete the local print queue that you setup on the 32Bit PC.
          Now that you are completed, you can now point to the queue on the server and the 32Bit
          and 64Bit PC's will automatically be given the print driver when they connect to the print
          queue.
          This doesn't happen all the time as alot of manufacturers build information into their 32Bit
          print drivers to make them work on a 64Bit box for sharing, but every now and then you get a
          pair of drivers that won't, therefore you would use the above procedures
          Hans
          • Destoned
            • Jul 2009
            • 24
            Re: Minolta di-1610
            Thanks for reply I will try with the BH162.
