Konica Minolta Bizhub C451 Install IC-409 Fiery
  • Oscar57
    • 79
    I need some input from anyone who has installed a IC-409 in a Konica C451. The install went pretty smooth and the Fiery boots up to a ready "00". But when I turn on the copier the Front Blue and Orange Lights Stay on. And I have no Control Panel Screen. I've done it twice and I've made sure the interface boards are well seated. Any ideas would be appreciated.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Maybe the following solution applies to your situation check this attachment from the SSD solution base.
    Now into Ip TV KODI Boxes
    • knightfall
      • Jul 2006
      • 633
      before installing the fiery did the copier come to a ready? did you install the vi504 or just remove the jumper board? usually the jumper board causes a blank screen when you remove the vi504 and dont replace the jumper board.
      Get your facts first, and then you can distort them as much as you please.
      • Rvale
        • 83
        Re: Konica Minolta Bizhub C451 Install IC-409 Fiery
        Hi there
        anyone of you have any idea on how to make them Show the Image Controller Settings under System 2 after you assemble the vi504 and fiery on them? i did it on many of them and it always worked great but i got three of them this week wich doesnt Show the Option at all, already tried new Firmware, older Firmware, initialization, nvram clear and nothing changed.
        any help will be very apreciated.
        thx
