fs 529 (bizhub 423) question
  • brent
    • Nov 2008
    • 1212
    this inner finisher is working ok. when you dont finish and staple. the problem I am having is when I staple. it of course brings the paper back into the machine and staples. once in a while it wont bring the copy back in all the way. and when it staples. it will get the first sheet and last will be ok. but one in the middle will not be stapled. I have cleaned the upper feed tires and still it does not work all the time. any thoughts on this?
    other then throw it away? lol thanks
    brent
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: fs 529 (bizhub 423) question
    If I remember in solutions there is a mylar or something that gets malformed or something....I don't remember what bulletin it was but you can find it under 423 solutions.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • Spidula
      Konica Minolta Technician
      • 83
      Sounds about right to me.
      Two mylars deep within the finisher. Tech advice tells you to strip the finisher down to take them off. However, once you have found said tech advice and spotted the mylars, a bit of jiggery pokery and you can just pull them out with a set of pliers. Don't worry about the black plastic, erm...things, that come off with the mylars.
      • brent
        • Nov 2008
        • 1212
        that is not my favorite machine in the world. I remember taking one apart one time.. not real fun
        I will take a look for the tech advice doc. thanks
        brent
