Roller damage
  • Carlos Herrera
    [Misc] Roller damage
    Hello, I have a problem with Bizhub C6501 separation roller rubber found Bypass feed tray section, installed as indicated in the service manual but soon begins to use peeling break apart, break up completely.
  • minimerlin
    • 851
    Re: Roller damage
    Hello back to you!
    Not sure what you want the forum to do for you though. Do you have a question?
    Please do not PM me without asking first.
    • knightfall
      • Jul 2006
      • 633
      Re: Roller damage
      then order a new roller and replace it.
      Get your facts first, and then you can distort them as much as you please.
      • RRodgers
        • Jun 2009
        • 1947
        Re: Roller damage
        Ummm is there a bypass tray on a C6501?!?!?! I'd have to check mine. (the one's I work(ed) on have PF units.
        Umm after some thought, yeah I guess there is. Sorry I've been stuck in the office setting up 951's. (with punch kits )
        • mrwho
          Major Asshole!
          • 4299
          Re: Roller damage
          Carlos, what's the part number of the roller you're replacing? I never had any roller break apart on that machine's bypass (or anywhere else, for that matter).
          If you have a picture, it could be even more helpful.
          Mascan42
          Ibid
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            Re: Roller damage
            I have actually been having the same problem with a 5501. Once a week for the past 3 months now I have been called out for jamming only to find the bypass sep roller completely shredded and in pieces throughout the machine, with nothing left on the sep hub. Still with lots of tread left.
            I am currently looking at replacing the torque limiter on the sep assembly thinking maybe it is giving too much resistance, but it seems to be taking some time to get this limiter. Once it is in and can confirm if this corrects the problem I will repost.
            • diouff
              • Dec 2011
              • 2
              Re: Roller damage
              Hello, Did anybody resolve the problem with damge of separate roller in bypass?
              • marlon29
                • May 2011
                • 49
                Re: Roller damage
                hello,
                we have encountered that problem and we have solved it by alligning the plate closest to it. It seems that the separation roller touches the surface of the guide plate causing it to tear apart
                hope this would help
