Konica C250 Imaging Unit Reset
  • patterson70
    • May 2010
    • 599
    Hello, I am about to install some new geniune imaging unit in a C250 and want to make sure the unit is reset to new (full bars). i think the customer was using third party units and so the above the display is says to replace the units but when I look in the Utilities area there are still many bars showing they are not needing replacement. When I put the genuine units in will this reset everything properly and make the message go away and give me full staus? If not, is there a service procedure I need to do? Thank in advance.
  • farhanali79
    Re: Konica C250 Imaging Unit Reset
    There is a chip installed in each unit so if you put a brand new imaging unit, it will show empty bars. you don't need to reset anything
    the bars show the 'usage', not the 'remaining usage'. If an IU is showing full bars and the machine is still running, it means that the IU lifestop option is manually disabled by someone in the maintenance menu
    • patterson70
      • May 2010
      • 599
      Very helpful, thank you, I thought full bars meant it was new.
      • rrrohan
        • Sep 2011
        • 1976
        funnily enough on the new range it does
