uninstalling a Hecon counter
  • jpowers
    [Misc] uninstalling a Hecon counter
    Does anyone know how to uninstall a Hecon counter? I have a Konica Minolta Bixhub 501 and I have removed the box on the side of the copies but it is still asking for a counter to be inserted before it will work.....Help please
  • emujo
    • Jun 2009
    • 3009
    Re: uninstalling a Hecon counter
    Service Mode, sub mode "function managment"..you must disable the hecon here...If you don't know how to get into service mode, call a qualified tech as you can do some unintentional damage here..Emujo
    • Shadow
      PHD in Sh!t Disturbing
      • Sep 2011
      • 455
      you also need to install the correct jumper on the end of the connector cable as well. if your lucky the tech that installed the counter would have secured the jumper in the area of the cable.
      if not you can refer to your wire diagram and locate the correct jump setting.
      $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
      • mrwho
        Major Asshole!
        • 4299
        If you don't and try it by chance, you'll burn some fuses and/or board.
        Mascan42
        Ibid
        • oldschool
          • Mar 2007
          • 245
          Most machines don't use that jumper anymore. If you do have the jumper; you wont need to get into the service modes. If you do need to go into the service modes; Just remember once in the service modes press "stop 9" to get to the management function choice option.
          Jamex Tech Support: Saving the world one phone call at a time.
