Load Check on Konica Minolta's
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Load Check on Konica Minolta's
    On a Konica Minolta bizhub 501 (B&W), In 'tech mode' I have found "Load Check" under "State Confirmation" in order to run 1 motor/solenoid/clutch individually so we can isolate problems, frozen mechanics or whatever.
    But where is it for the bizhub C360 or the older C250??? Help?
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • 907tec
    • 434
    Re: Load Check on Konica Minolta's
    I believe that the "Load Check" was a vestige of the Konica days. The other two devices you listed do not have that mode because they take after their father, Minolta.
    • mrwho
      Major Asshole!
      • 4299
      True. Minolta-fathered Konicas were a bitch to troubleshoot. Unfortunately, with the merger, the worst part of the two was kept while the better part is slowly dying. I'm glad to be servicing mainly Ricohs nowadays.
      Mascan42
      Ibid
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Load check is back by popular demand in the current range of colour machines.
        It was not present in the c360 series, but having said that, and having "grown up" servicing the minolta side of things, I've never really used it much. Don't know what the big deal is. I've never had any issues troubleshooting electrical devices without that mode. Sensor check has always been there for testing sensors etc.
        There is sort of a load check for finishing devices on the 360 series.
