bizhub 600 feed issue.
  • chocolab
    • Jan 2012
    • 10
    hello everyone,
    i have a bizhub 600 that will try to feed paper then pop a message that says " open tray 1 rail and reload paper stack"
    i swapped the feed unit with tray 2 and the problem followed the unit to tray 2. i swapped sensors around but it isn't
    any of the sensors. another tech replaced the clutches and rollers a week ago. i cant find anything on this on kmbs website.
    iany help would be appreciated. thanks in advance.
  • RRodgers
    • Jun 2009
    • 1947
    Re: bizhub 600 feed issue.
    Originally posted by chocolab
    hello everyone,
    When he replaced the rollers did he change just the rubber or did he replace the whole hub with the rubber as well?
    • chocolab
      • Jan 2012
      • 10
      im not really sure, but will ask him tomorrow
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • chocolab
          • Jan 2012
          • 10
          talked to tech and he said he replaced rubber with hub.
          • RRodgers
            • Jun 2009
            • 1947
            check to be sure that the shafts that the one ways ride on are not glazed over. If so use some scotch bright to scuff them up.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Please tell me more
              • Mr Spock
                Vulcan Inventor of Death
                • Aug 2006
                • 2064
                There is a bulletin about feed issues on this style of feeder. Not sure if it covers this model. The roller that feeds the paper out of the unit (conv roller under the metal cover on right side). has been know to wear prematurely and cause the paper to hit the idler instead of the nip. This causes it to not feed in a timely manner. They updated the roller and idlers. I will see if I can find the bulletin.
                • chocolab
                  • Jan 2012
                  • 10
                  i ordered the whole feed unit, will update after i put it in.
                  • chocolab
                    • Jan 2012
                    • 10
                    didnt want to putz with it anymore so i just replaced the feed unit, and that did take care of it.
