C353 with Error C2152
  • lawdon
    • May 2025
    [Error Code] C353 with Error C2152
    Hi i have a mchine C353, there is the error code i removed and dismatled the machine cleaned it changed the sensor that activates the transfer belt unit also changed the clutch in the fusing drive unit re assembled the machine reseted the code switched on and after it comes to actuate the Transfer belt the error code comes again any help please ??? this machine is getting me crazy
    thanks
  • remati
    • 149
    Re: C353 with Error C2152
    thanks
    ...change the transfer belt....too
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        try installing a hand made spacer shim (s) under the actuator block on the transfer belt. The issue can be caused by chassis warping/twisting/deformation in transit. Making the sensor at the back too far away from the belt.
        I have heard of the sledge hammer approach being done by backyard butchers - use your own imagination as to how that's done...
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          They came out with a revised actuator and mounting block for this issue. I will try to get the part numbers.
          • jagatiswaran
            when u open the unit service it, did u notice the retraction spring with gear where it contacts direct to ITB ? compare with new one , the position should be up ! dats y sometimes
            eventhough u changed the clutch it still shows c-2152 error
