Was called out after user replace staples on 4/2. There was a misfeed message on screen. If you press the next scan/fax job button it also shows message to replace staples. The elevator tray section was raised up high. The staple unit came completely off track and the guide that holds the stapling edge of the paper came loose. Got all of that back on. Checked staple cartridge to make sure everything looked good. No change after this. Misfeed comes up at power on. There are no jam codes related to this. No other error codes since december. The elevator lift never moves or homes in.
Checked for paper in finisher. Manually ran a thick paper through it. Removed horizontal unit and disassembled it to check all paper paths. Inspected all sensors and cleaned them. Look at sensor check and see that some sensors seem to work such as front finisher door and some elevator sensors. The ones that I noticed are paper passage sensors 1 & 2 (PS1 & PS2) are both showing 1 which SM saying happens when paper in blocking it. Found a knowledge base artical about a solenoid that switches the entrance guide that can cause misfeed jams with PS1 or PS2. I checked all of that. I measure continuity between wires to the board for PS1 and PS2 all good. I checked for pinched wires and checked all wires if they are grounding.
Anyone have any tip on this issue before I start replace boards and such. Spend the entire day on this machine and another tech with high experience joined me for 2/3 of this time.
Main unit works fine without finisher.
