282 duplex (output) option missing
  • Phrag
    • Oct 2012
    • 417
    [Misc] 282 duplex (output) option missing
    I've got a bit of an issue with a bizhub 282. The double sided option on copy mode is missing.
    Now, the fuser had been changed a month or so back due to it causing some paper curl issues. I inquired to whether the client noticed the option missing since then, but they only decided to start doing duplex the other day.
    Basically, I don't know if this anomaly has been with the machine for it's entire life, or whether something has caused it recently.
    I've also tried firmware to no avail. I also tried to force duplex through Tech Rep. Choice (I think) and it still prints 2 single sides.
    Please note that the RADF WILL read both sides.
    Any help would be appreciated. I'm only a bit of a rookie tech at the moment, but I've tried all I can think of.
  • NRTech
    • Apr 2013
    • 45
    Re: 282 duplex (output) option missing
    check the connector between the duplex and the main body. if this is off, loose or damaged the machine can fail to detect the duplex and disables the option.
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • Darren King
        copiertech
        • 652
        Is the switchback assembly installed?
        • Phrag
          • Oct 2012
          • 417
          cheers guys. I'll have a look at those. I'll let you know how I get on.
          EDIT: It turns out one of the pins was bent. After straightening it up, duplex now works.
          Cheers for the help.
          (So I'm told this macine came back in with a C5102 code. Oh joy.)
