Konica C250 Close Section Properly on display
  • patterson70
    • May 2010
    • 605
    For a Konica C250 the display shows "Close Section Properly" for the lower right side door (for drawer 2, there are only two drawers). The door is shut as properly as I can get it but the display still shows the message. Has anyone seen this before? Thanks in advance.
  • BennyAU
    • Dec 2012
    • 25
    Re: Konica C250 Close Section Properly on display
    make sure the sensor is working via the sensor check section in service mode.
    if it does work, check the plastic flag that triggers the sensor on the door itself, make sure it hasnt snapped off (or that the sensor hasnt fallen out of the bracket to hold it in position)
    • SmellsHot
      Head Tech
      • 512
      look for the sensor where the door closes. Once you find it take a q-tip and stick it in the sensor. If you message goes away then your tab is broke on the door. If you wanna be cheap just cut the q-tip so the door will close.....
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • patterson70
        • May 2010
        • 605
        Thank you both for the information and advice. I wanted to elaborate that the lower door does not appear to have the same type of sensor as the main upper door where you an could insert a Q-tip to verify whether it works. There appears to be a very small dual eye sensor made of glass at the top center where the door shuts. Either the door has a broken arm that i could not tell where it broke off, which I could not see anywhere, or the sensor went bad? The customer is rough with the machine so maybe it broke internally?
        • Darren King
          copiertech
          • 652
          The sensor flag is on the back of the door. It fits into a slot in the feed assembly. I have had the sensor become unplugged. You will have to remove the feed assembly to check.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
