image quality problem Minolta bizhub 750
  • cristian
    • 179
    After I was changing the drum, blade and the developer i have some bad copies.
    Attached i put a sample. Any ideeas?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: image quality problem Minolta bizhub 750
    did you reset counters and run the appropriate adjustments?
    Crash the machine just before fuser and see if images is good or bad.
    If good then I would check the fuser unit if bad then check the transfer section and drum image.
    • cristian
      • 179
      image bad before the fuser. i ve checked all the transfer part, wires cleaned, grid cleaned,exp lamp cleaned,tcsb cleaned.When running adjustments :error 1 at auto max density and also auto gamma :error 1.New drum+ blade, new developer.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Mr Spock
          • Aug 2006
          • 2064
          Under the drum on the left side is 2 sensors these are you gamma and max density sensors. If they are dirty then this is the issue. They may be bad but I have not had to replace them. Clean with air only. Also make sure the grid is fully seated.
          • cristian
            • 179
            Problem solved.I have cleaned the sensors, and i have found that one corotron wire has 2 pieces of 1 cm covered in black toner (after i have cleaned with alcohol- i need glasses) .I could not clean with alcohol, nor with fibreglass, so i had to do it with my nails.The wire was a little sinuous, but the image quality is OK now. I will replace the wire a.s.a.p..
            Attention: 2 distinct cm not shiny as gold on the corotron wire may give this fault
            • JR2ALTA
              • Feb 2010
              • 2028
              Buy a pencil eraser, ones designed to look like pencils can be sharpened so you reach both side of wire
