Bizhub 350; missfeeds tray 1
  • xeroid
    Document Technologies Pro
    • 148
    [Jamming] Bizhub 350; missfeeds tray 1
    New Rollers and feed clutch. Intermittently declares a missfeed, paper never makes it out of the tray. Slight LE buckle in the center of the sheet when I slowly remove the paper tray. Is there something I am missing?
  • SmellsHot
    Head Tech
    • 512
    Re: Bizhub 350; missfeeds tray 1
    cracked cassete where frame meets locking capture, can cause intermittent jamming issues. Also make sure the arm is the modified one(or just shim up the cassette where the arm for the feed makes contact) When you say feed clutch are you refearing to the bearings the feed rollers slide into? These should be replaced with the tires everytime. Also rough up the shaft too.
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        I was going to say that.
        • xeroid
          • 148
          Thanks for the experienced replies. The cassette and catch were fine. Roughing the polished area of the shafts where the one-way clutch turns and applying a little grease to the clutches appears to have solved the pblm. Feel a little embarassed I wasted time and money elsewhere. Will order those clutch gears with rollers in the future. Thanks again for the input.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Don't feel bad about, I went through the same thing first time it happened to me. I keep a set of the rollers and the one way bearings(clutch) In my car stock. I've rarely changed the actual feed clutch in the back of the machine but have had to before. It can be a pain. Especially tray2.
            • mo0651
              • 1054
              Those one-way clutches are more the problem than the roller itself. They get dirty quickly and where out.
